1988 Silverton manually check the fuel
On the 88 37 MotorYacht it is 1 big tank centerline, forward of the engines. Cant speak to the convertible.
Why keep guessing when the OP won't come back to clear things up.
$200 worth of fuel may only be 50 or 60 gallons. You can run thru that pretty quickly.
https://www.youtube.com/watch?v=z4c8_NnBW4s A agree, fix it. Hopefully you don't have to undo structure to get to the sending unit.
No boat will have a straight filler hose to the tank... if you want to stick a tank you need to have a plug that is accessible on the tank. It s pretty common on diesel boats but as I said earlier opening up a gas tank is never a good idea for obvious safety reasons
Just fix the damn thing... :)
I'll wholeheartedly agree with my friend Pascal here. Gasoline tanks should NOT be sounded. That's a diesel thing, NOT a gasoline thing. Fix the sender, install a flowmeter, calibrate the flowmeter, then rely on it. Always far more accurate than a float level type sender. Do NOT get in the habit of manually sounding a gasoline tank! Boating disasters is my profession - please trust me that it is a horrendously bad idea.
