I'm looking for opinions.
My carb was fairly dirty so I cleaned it with carb cleaner along with the flame arrestor. Now the engine wants to stall at idle. I replaced the water separator, the fuel filter in the carb, and even ran from a gas can for 10 minutes to make sure I didn't have a batch of bad gas. The electric choke works properly and all linkage is fine. I cleaned the inside of the towers in my distributor cap and replaced the rotor in hopes it was that.
What I think happened was when I sprayed the top of the carb and into the bowl vent, I inadvertently got some dirt down the vent and that dirt is now sitting in one or both of the jets. To save me the joy of having to remove the carb for service, I was going to try to clean it again with carb cleaner, spraying a lot into the vent until the engine stalls. Then I will not start it for like 30 minutes to give that carb cleaner time to act on the jets. Another idea I had was to maybe fill the water separator 50-50 with Sea Foam and let that run through. Does anybody else have any ideas? Thanks!
