2007 Sea Ray 185 with 4.3L Alpha I MCM Sterndrive - I have come to end of 20 hr break-in period and need to change engine oil and filter along with gear lube. Oil filter is on port side of this V6 engine. It looks like I need to remove the port side vertical longitudinal white board in the engine compartment and the long blower hose in order to access the oil filter. Any tricks or work arounds for this? Is is better to drain engine oil or pump it our through the dip stick tube?
