I had a survey done last week on a 2000 340 sundancer with 7.4 magnum horizon engines (550 hours). Nothing major on the survey, Seller agreed to install 2 new batteries and one alternate. I ended up paying for an oil change.
--upon a 2nd sea trial showing that all is well with the boat (holding charge...) we were underway at around 4000 RPMs and the low oil alarm went on. the pressure was reading around 7! We had to bring the RPMS down to around 2000 and the alarm went off --pressure was at around 40 the whole way in. When we got back to the dock we realized the oil change wasnt done. An independent mechanic at the dock changed the filter and placed a mechanical gage on the motor. This time oil pressure seemed fine when we increased rpms on the mechanical gage. The independent Mechainc said the oil is very dirty. --still has viscosity, but hasnt been changed in a while. It was also low by a 1/2 quart. They are going to change the oil and filter and take me out for a 3rd sea trial. My questions are as follows:
1-- Is there anything specifically I should be doing on RPMs... for this Sea Trial?
2-- Should I run it for 10 minutes, 20 minutes???
3-- If the alarm goes on again, is it reason enough to walk away from this boat?
4-- Due to the existing oil being black and an alarm going on already --Is that enough reason to walk away from the boat?
Had a compression test done at time of survey --all cylinders came back within normal range. Does that mean anything in this case? does it rule out any lack of lubrication issues?
I realize these are a lot of questions --Any advice would greatly be appreciated
Thank you
Thank you
