2000 340 with 7.4 v drives. New AGM batteries(4)group 27 installed last fall. While hooked to shore power, experienced a problem with head(vacuflush) kicking breaker. Turns out it was low voltage. Port side was discharged. After running generator and taking a 45 minute cruise voltmeter on port bank finally came up to 14 volts. Head worked fine. Do I have a problem with the on board charger or bad battery(s). Didn't have a voltmeter so could do no diagnostics.
TGCZAR
TGCZAR
