350 MPI Horizon (25 Sundancer)
Shaun78
In addition to the bravo 3 drive pickup there is a pickup through the bottom where the macerator discharge USED to be. It is connected, I am guessing to the water pump for add'l water flow to the heat exchanger. Anyone else have this or hear of this? It is probably over kill but not a bad idea for add'l water flow. It is a closed cooling system so the more flow the cooler the engine will be.
Could the thru hull seacock to cool the engine/heat exchanger be the only way it gets water or the bravo pickup definately has to be hooked up and the thru hull is an add'l water cooling intake?
