350 sputtering under load.
Originally posted by WALSHIE
I just used the two-step method as described here on Boatered and elsewhere:
Once you are sure that the engine is at #1 TDC the following valves/rockers can be adjusted:
exhaust - #1, #3, #4, #8
intake - #1, #2, #5, #7
Rotate the crank 360 degrees and set the other half of the valves
exhaust - #2, #5, #6, #7
intake - #3, #4, #6, #8
Okay, I can dig it! You learn something new each day.
