3780 Anchor Rode Locker Drain
bodkin creek george
Is there a drain for the Anchor rode locker/ If so where does it drain to?
Thanks for any help.
George
Most boats have a drain in the bottom of the anchor well that drains to the outside of the boat. Stand at your bow and look around. Most likely you will see a drain hole there
There are 2 drains at the bottom front corners.
There are 2 clamshell covers on the outside.
There's no problem for you to drill a hole in the lowest aft corner and seal the edges of the hole with epoxy. Add a clam shell to make it look kool.
