99 330 Dancer Prop Selection
David M
I am in the process of dialing in the props on my new to me 99 330 Dancer w/ 2007 6.2 Horizons.
Can anybody steer me in the right direction for the proper props for this setup?
I am looking for a smooth (less vibration) ride so I know I have to go to 4 or 5 blades.
What I do not know is the max diameter I can run in the prop pockets w/o decrementing performance, nor do I know the correct pitch. The current props IIRC are bronze 3 blades 16X16. I need to get a direct read tach for the current max RPM. The dash shows 4800. I have seen many 20" diameter both here in the classifieds and on line that may do the job. No sense in even researching them if 20" is too large.
Max engine RPM (per Mercruiser) is 5200, BUT, the transmission max's out at 5000. I would like to get a 5000-5100 max RPM from the props. Yes I know it is pushing the envelope, however in 30+ year of boat ownership, I can count on both hands the number of times I have ever spent any time more than 60 seconds at WOT.
Any and all input welcome
TIA
DPM
