Need help quick. I am starting the install of an AC unit. I currently have a 1/2 inch intake already in the hull. The intall kit came with a 3/4 intake. All openings to the pump are 3/4 except for one -- the hose nipple into the strainer, which is only 1/2 inch. Anyone see any problem with just leaving the 1/2 intake in, instead of using the 3/4 intake? My understanding is once the nipple reduces to 1/2 inch, that is the best flow you'll get to the pump -- so what does it matter if the reduction to 1/2 inch is made at the intake instead. Thanks in adavance.
