Air Conditioning Pump Lost prime
Originally posted by divedaddy
David,
A 330 DA question -- my discharge line has a small ball valve at the through hull under the forward berth. Does yours, or do I have a custom mod of some kind ?
Mine has the same setup. I can't say if it is custom and we both have it or if it came from the factory that way.
I think the A/C was an option. My best edumacated guess would be the A/C was a dealer installed option and the thru hull and ball valve were shipped on all boats. I wonder if Mrs. Robinson has the same setup.
hook up a small hand pump to your discharge thru hull by inserting the in line to the thru hull and pump when the ac starts.
TIC-
Welcome to the site. Leaving the valve open should not be a problem. The subject of this thread is the excption rather than the rule.
Guys,
I'm unable to get to my boat for the next few days due to work, but will next try the reverse flush method suggested above in hopes of resolving the air lock. I will report the outcome once I have had an opportunity to give it a try. Thanks again to all for the help.
In the meantime, here's a couple replies from me regarding other's commentary within this tread. Perhaps they will clarify a couple issues......
KiDa:
I do in fact keep my boat in the water, but have had it out of the water several times. I have never closed the seacocks during haulout, and have never lost prime. Perhaps I was fortunate, but in this case, I believe my winterizing technique, or lack thereof, caused my air lock. Also, my pump is in fact below the waterline, so that should not be an issue either.
As for the Bleed Valve, there is a "T" fitting (diverter valve) situated horizontally directly downstream of the pump. One direction of flow goes to the A/C unit, and the other merely diverts flow into my shower sump through a small line.
Lastly, no, I did not tape up my through-hull during the winter, but having said that, I knew I had lost prime while I was introducing anti-freeze during winterization. I informed my mechanic of this, and thought he had rectified the situation, but appearantly not, as I discovered that I still had no flow this spring during re-comissioning. (Lucky for me we did not have a harsh winter.)
PascalG:
I too have not run across any self priming A/C pumps, but I thought you might find it interesting that the manufacturer of my A/C (Marine Air Systems) makes a secondary reservoir intended to be utilized in scenarios where a pump cannot be mounted below the waterline. It is about the size of a gas tank on a push mower, and is intended to be mounted upstream of the pump and slightly above it, which then makes the pump act as if it is in fact mounted below the waterline. Interesting application.
Well, as promised, I'm reporting back as to the re-priming of my A/C pump:
Despite all the recommendations, I did not have to utilize any of the methods suggested. When I got the opportunity to go back to the boat with the mission at hand to get the pump primed, I simply made a last ditch effort to do it the easy way by cracking the bleed valve on the discharge side of the pump again. After doing so a couple times, low and behold, I had water circulating.
I can't offer any explaination to why this worked this time but not on the first try, but I was relieved to have the system in working order.
I do think I am going to add a flush receptical just prior to the pump (one similar to those utilized in a car's cooling system) before next winter. This was suggested early on in this thread, and would allow for quick and easy re-priming of the pump by merely connecting a water hose there.
As for now though, things went the easy way.
Thanks again for all the suggestions.
V1
Glad it worked out. Mine had the same problem this year--never before. Had to blow the airlock out of the hose before it started to pump.
I was even luckier. I forgot to close the seacock when I hauled the boat a month ago. Put the boat back in the water and the a/c pump started working again with no hesitation.
G
