ok, im doing a gimbal assy on a 1990 searay, why you ask, cause i'm an ass.
anyways, the gimbal i got has an offset bolt pattern in that is has 2 bolt holes on the bottom 1 on top & 1 on the side. the y pipe has conventional 2 & 2.
from what i've learned, this gimbal is from the mid 80's. i found a 3" y pipe with the right bolt pattern but it will not meet up with my exhaust elbows, i even have 3" to 4" elbows but no good.
can i get away with using only 3 of the 4 bolts? i know they wouldn't put them there if they didn't need it but what other solution is there?
tear this gimbal out & start over?
ive already installed new bellows, shift cable, trim switches, etc.,..
