Originally posted by jrpar
+1 on matching the working load of the shackle to the rode (or upsizing if possible)
To address the question.
Think that's adequate for a 43' 20k boat?
Ground tackle needs to be matched to the application.
Seems like a light setup for a 43' vessel.
Starting point recommendations for a working anchor would point to:
Nominal Anchor size: 40#-Danforth / 45#-Plow / 40#-Delta
Rode: 3/8" Chain (1/2" rode if not all chain)
This is nominal for moderate wind/wave with good bottom conditions with decent scope.
Storm setup would bump up (at a minimum) the anchor size.
All depends on your cruising style..
If you're only out for the day in protected waters with good bottom conditions, your setup would probably work fine.
However, if you do a lot of overnighting and conditions may change (ie: storm, crappy bottom conditions, etc.) I'd go prefer to have a beefier setup.
That's just my opinion.. (but I do sleep well at night on the hook...)
