Ants!!!!
firepiper
Hello, I have carpenter ant on my boat, (Fiberglass). I thought they were from the trees at home, but i've been in the water for three weeks and i'm killing them all the time. I can't figure out from where they come. I've tryed the spra bombs, and the ant traps to no avail. Any Ideas?
Generally if you have that problem it is a bad sign! Carpenter ants generally attack wet and rotting wood. Check your transom for rot. Also your stringers. I had that problem on an old fiberglass boat I had and that is what I found. Rotten transom. I ended up scrapping it because it was more to fix it than the boat was worth. Not saying yours is that bad but carpenter ants generally don't keep coming unless there is a food source.
Also, spray around the cleats and dock lines, it keeps bugs etc. from getting on the boat. Of cours since they are already there you need to find where they are. Spraying the lines definitely helps with future boardings!
I already replaced all the wood in the transom, it was damp below the waterline, while i was putting in the transom door. No ants there. My survey showed no moisture to speak of. I'm baffled. I sealed up the whole boat and set off a couple of those spray bombs, but, they are still there.
I know the immediate instinct is to crush the little SOBs but you could watch to see where they are going. That will usually lead to the problem area. Do you have a wood dock or steel? As Bill said, spray the lines and such. See if they are coming from the dock. Did you see them on the boat when it was at the house?
Yes they were there at home. Thought they were falling from the oak tree above. I am on a mooring, so that takes care of lines...unless they swim!
Good idea, watch where they go. You could also try sounding with a mallet. Hope you don't find any dead spots.
Carpenter Ants are unlike Termites that eat wood. Carpenter Ants burrow to make nests...neither are good.
Pesticides, Poisons and Secret Formulas.
Toxic Sprays: Most pesticides available to the public will kill any insect that they come in contact with while still wet. Once dry, the residual effect is minimal and has very little effect on insects.
Ant Dusts: Diatomaceous earth is sold in a variety of containers with convincing trade names. The basic product can also be purchased in much less expensive plain plastic bags at most garden stores.
Toxic chlorpyrifos is now off the market and illegal to use in Canada and U.S.A.
Boric Acid dust: It is very difficult to inject into a nesting cavity without proper equipment. Do not put it in exposed areas.
Ant Poisons sold over the counter at most hardware stores have little if any effect on carpenter ants
Ant Traps are actually not traps. The little tin cans with holes in the side contain borax. They have no effect on carpenter ants.
Secret Formulas: If you find one that works, patent it immediately. Scientists around the world have been searching for years for ingredients that will attract and kill or repel carpenter ants. Some things that homeowners have tried include cinnamon, cayenne pepper, moth balls, boric acid and icing sugar.
None of them have been proven effective.
I do not know if this will work on carpenter ants, but I have been successful at home and on the boat in preventing ants from entering by placing a bead of liquid detergent where the ants enter. For some unknown reason, they will not cross that bead. However, they will go around it if possible.
So at home I placed a bead all along the baseboards of the rooms where they were a problem. At the boat's dock, I encircled all cleats with a bead of liquid detergent which kept them from climbing the dock lines and entering my boat.
Again, I have no experience specifically with carpenter ants......
Good luck!
Carbaryl, better known as SEVIN and available at most garden centers is very effective on ants of all kinds and if applied properly will leave a residual that will kill the ants if they walk thru it. It can also be dragged back to the nest to kill there also. Diazanon will also kill ants in similar fashion. As with any insecticide, follow the label directions pertaining to handling and disposal.
I had a huge problem with Carpenter ants in my house a few years ago. They were living in some rotted wood in an old deck and came into the house for food or whatever. Barrier spraying did no good, they find a way in. They detect the spray and won't walk in it. You have to bait them. The answer was a product called Advance Carpenter Ant Bait. You can buy a jug of it off the internet for maybe $60. It's about the consistency of kitty litter and you sprinkle it around the house (or in your case, maybe in your bilge, just not anywhere that's wet.) It disappears. They eat enough of it, feed it to the kids, the colony crashes, bye bye. It takes a while, like weeks.
I just had some come back this year and have to buy some more of it, but, they were gone for 3-4 years. Everything else I ever bought to deal with them was a waste of money.
How long have you had the boat? How long ago was the survey? I will stick to my original response that says you do have rotten wood somewere. Being in the home repair business for as long as I have I see those and I know immediately to look for rotten wood. Not to be Mr. Gloom and Doom but you may not see it but I truely believe that there is rotten wood somewhere. I would have thought that when it was surveyed that they would have found the rot.. unless it is in a totally unaccessable area. We all know boats don't have any of those though right? ;-)
A couple of years ago I had black ants in the boat and I thought they where carpenter but I was assured they weren't so you may not have carpenter but just a black ant of some sort. Any way, I watched one as it worked it's way up the dock line to the boat. Then onto the rub rail and started moving forward in a very deliberate path, on the rub rail. About mid ship I have a joint in the black plastic rub rail and he climbed right in and couple more came out a second or two later. I also noticed a brown streak running out of that same spot and down the hull. A can of Raid did the job. I sprayed it into the opening in the rub rail as best I could a few times throughout the day. I also sprayed a little on end of the lines. That did the trick and I never saw them again. If you can't get the entrance to the nest, spray on a regular path and the ants will carry the poison to the nest taking them all out. The Raid did eat the wax off the boat where it came in contact but it was no big deal. You may want consider something else and I just read that insect poison with Borax, as the active ingredient, is a natural way to kill them and many other insects.
Good luck
Recently had black ant in our home, I think carpenter ants. Went to Wal-Mart and bought two different ant traps. Terro seemed to work best. Placed both brands around the area that we found ants. Came home the next day and found several marching to one of the Terro traps and also a bunch going from the trap. Followed the retreating troops and found where they were coming into the room around a window sill. Moved the traps closer to that spot so they didn't have as far to travel. Week later no more ants to be found.
Try catching a few and have an exterminator look at them to confirm what they are. Good luck.
