Hello all,
In an earlier post I indicated that the inlet pump shaft seal on my Crown Head Deep Draft appeared to be leaking at the seam between the motor and the impeller housing.
This morning I went to the marina and purchased a new inlet pump housing complete with a new seal, new gasket, new check valve ball and spring.
After installation it is still leaking, seemingly from the same spot. Any ideas what I could have missed?
Thanks in advance for the help!
Jeff
Jeff
