Recently had my 350 MAG MPI 5.7L Mercruiser engine tuned up. Replaced plugs, distributor cap, rotor, V8 wire set, water-separating fuel filter, in-line fuel filter, etc. with all new Mercruiser parts. Bay tested for 15 min. & engine ran fine. Next day, engine runs rough and loses power over 2000 rpm. Ran cylinder compression test and fuel pressure test and everything checked out OK. Started replacing all items one by one until we discovered the distributor cap was causing the problem. Replaced the distributor cap with a new Mercruiser cap and had same issue again 2nd time out. I have a 3rd cap now with the same problems. My mechanic has been buying his parts from Kellogg Wholesale Marine in CT. There are 2 other boats at my marina with similar engines that were tuned up at the same time. We are all experiencing similar problems. I suggested the mechanic source new distributor caps from somewhere else.
Anyone else having the same issues?
