Arching At Ignition Coil
Mzzola
I have a 1998 MerCruiser 4.3LH Alpha Engine. I have a loud popping noise that almost sounds like backfiring, that I have found to be an electrical arch jumping from the center wire on the ignition coil to the positive or negative terminal (not sure) also on the top of the ignition coil. I have replaced the ignition coil two seasons now in a row. In the past, I replaced the center cable from the distributor cap to the ignition coil with a heavier gauge wire and this stopped the problem until now. The voltage gauge on the boat is not very accurate. A had held voltage meter checked at the terminals of the voltage meter, while the motor is running, reads almost 14 volts. Is this a normal voltage reading? Any ideas about what is causing this arching and the ignition coil to burn out? Thanks from Mike
