Battery Question?
Sea Bitt
Battery Question?
Can you and or do manufactures put additional batteries in the cabins of boats? Or is that a dangerous situation because of the out gassing from the battery during charging. I was thinking of added an additional battery and it would be easier to put it in the bilge area under the cabin or do all batteries need to be in the engine room because of ventilation?
Bow thruster batteries are located in the bow of the boat, usually under the bed. I highly recommend using maintenance free AGM batteries to prevent any gasses from escsaping from inside the battery.
AGM batteries are non corrosive, and have glass mat inside. if you break one open, it does not leak acid everywhere. Deca, Optima, are a few brands out there.
they can also be mounted in any position.
Yes, only use an AGM in living areas.
The cabin and the bilge under the cabin are to different areas. The bilge area is vented. The cabin is not. Use the bilge for batteries.
I've seen plenty of sailboats with wet cell batteries in many locations other than the bildge and engine area. But I would stick with AGM type batteries for those type of locations.
I agree with GSent, I have AGM batteries for my bowthruster under the forward berth for the past 6 years as recommended by the thruster manufacturer.
AGMs are ok in living areas (including bilges under living quarters). i'd rather have somewhere else if possible though...
Lead Acid are not... I think ABYC standards dont "allow" lead acids in living spaces.
