What is the proper way to use a battery switch.(besides the obvous turning part) I was reading in the owner's manual that you should never turn it with the batter running. So let's look at this example:
I hang out and run one battery down. I turn the switch to the other battery to start the engine and it starts. Do I then turn it to the both battery position to charge both of them?
Is it best to start the boat off both batteries even if one is dead, therefore charging the dead one while using the starting power of the good one?
Any input would be great.
MJK
MJK
