"This is only recommended for Sunbrella material...I have done it this way with the bleach and was amazed at the results"...
Marine tops and covers care & cleaning
One of the best ways to keep Sunbrella® brand fabrics looking good and to delay deep or vigorous cleanings is to properly maintain the fabrics. This can be accomplished by simply brushing off dirt before it becomes embedded in the fabrics, wiping up spills as soon as they occur or spot cleaning soon after stains occur.
Marine tops and covers care & cleaning (pdf) / Stain chart
When it’s time for a thorough cleaning, Sunbrella fabrics can be cleaned while still on a boat or, size permitting, they can be removed for cleaning in a washing machine or dockside. When cleaning Sunbrella fabrics, it is important to observe the following:
* Always use a mild soap such as Ivory Snow, Dreft or Woolite.
* Water should be cold to lukewarm (Never more than 100°F/38°C.)
* Rinse thoroughly to remove all soap residue.
* Air dry only. Never apply heat to Sunbrella fabrics.
General or light cleaning
To clean Sunbrella while still on a boat, follow these simple steps:
* Brush off loose dirt.
* Hose down.
* Prepare a cleaning solution of water and mild soap such as Ivory Snow, Dreft or Woolite (no detergents).
* Use a soft bristle brush to clean.
* Allow cleaning solution to soak into the fabric.
* Rinse thoroughly until all soap residue is removed.
* Air dry.
* May not require re-treatment depending on the age of the fabric.
If stubborn stains persist, you can use a diluted chlorine bleach/soap mixture for spot cleaning of mildew, roof run-off or other similar stains (see our Stain Chart for specific recommendations).
Heavy cleaning for stubborn stains and mildew
Sunbrella fabric does not promote mildew growth, however, mildew may grow on dirt and other foreign substances that are not removed from the fabric. To clean mildew, or other stubborn stains:
* Eight ounces (one cup) of chlorine bleach.
* Two ounces (1/4 cup) of mild soap and/or detergent.
* One gallon of water.
* Clean with soft bristle brush.
* Allow mixture to soak into the fabric for up to 15 minutes.
* Air dry.
* Repeat if necessary.
* Re-treatment of fabric for water and stain resistance will be necessary.
Remember to protect the area around your Sunbrella fabric if using a bleach solution. Carpet or other fabrics that are not Sunbrella may have an adverse reaction to the bleach. If a boat cover is suitable in size for a washing machine, these steps should be followed:
* Use mild soap and/or detergent.
* For heavier stains add 1 cup of bleach to wash.
* Wash and rinse in cold water.
* Air dry. Never apply heat to Sunbrella.
* Re-treatment for water and stain resistance will be necessary after machine washing.
