We attempted to go. But never made it... Here's what happened.
We got to the boat at low tide, The boat was floating fine in the slip and I knew they had dredged over the winter, so I thought all would be good. We pull out of the slip, head down the fairway and start kicking up a lot of mud. We are just about in the river so I figure I'll just keep going. It was pretty windy that day, now they tell me the wind was blowing all the water out of the marina. So between that and low tide there was not enough water.
Out in the river I throttled up, and it didn't sound right. I go down and check the strainers - plugged with mud. I couldn't even pull the baskets out. I had to shop-vac the mud out first. Got the port side cleaned out and running good, so we are idling along on one engine, while I am trying to clean the other. Turns out the intake hose was all plugged up also, I tried opening the sea cock with the strainer open and got nothing. I started flushing the line out with a garden hose, I almost got it when all of a sudden the starboard shaft seal started smoking and then seized to the shaft, and then ripped free from the shaft log. Water then started pouring in from around the shaft. At that point I dropped the anchor and got out the rescue tape, and sealed up the leak. That stuff is great to have on board.
I think what happend is the shaft seal cooling water lines were also plugged and from idling along on the port engine, with the starboard spinning from the movement, the shaft seal overheated. I have a crossover line that connects the two seals, but that must have been plugged.
At this point there was no continuing, we got sea-towed back to the marina, and went to a local restaraunt for Mothers Day Dinner.
One of these days though we will make it there.
