closed cooling system (new owner)
dazeoff-wy
I am going to winterize my boat this weekend. this is my first boat this size. I want to make sure the closed cooling system is ready. Getting the internal portion is no problem. I am not sure where the intake to the heat exchanger is located. I believe it is in the outdrive if so what is the best way to blow it out or do I need to put antifreeze in it somehow. I have a 87 Carver Montego 27ft with twin mercruisers with alpha 1 outdrives.
Montego 2757
Put muffs on the outdrive and run antifreeze through until you see it coming out the exhaust.
Just wondering why you are asking the same question in multiple forums?
sorry about the multiple post but was not getting response until I posted here[:-irked]
