Control Cables
Viking76
Morse Red Jacket VS Teleflex Black Jacket control cables, is one better than the other?
The Red Type 33 general purpose cable is just OK. The good thing about this cable is that you can put different ends on them to use with different engines and control boxes. The Teleflex and OEM cable are much better, but you have to be exact when it comes to the type of connectors the cable has. If you have a stock cable to compare with, you will be able to match it to the cable you're buying.
I put the TFX Extreme on my flybridge Bayliner. Pretty convoluted cable path. They work very well.
Good input, however, is there any appreciable difference between the Red Jacket and Black jacket control cables? Is one better than the other? The ends of both appear to be universal.
