Hello all -
Looking to upgrade to electric fuel pumps on my 90's carbed Mercruiser 454s- tired of 5 minute crankup times.
4 tanks are far forward and deep (below engines) plus I run two sets of fuel/water seps to keep crud outta the engines.
Thinking of replacing the mechanical pumps with block-off plates, wiring in Carter 4070 pumps which can handle up to 70gph.....hope I never need that!
Could use recommendations on which model Carters if 4070 is not best, any hints on wiring and any other things to be careful off?
Had a mechanic tell me to mount 4070 to same block off plate so no new fuel lines to run....and connect to an oil pressure switch so if oil PSI lost they cut off. Does this make sense?
Thanks!
O
Thanks!
O
