The "large" skeg at the very bottom of the O/B ( ie: below the prop ) should be straight. It is typically an integral part of the "leg" casting.
BUT the smallish "skeg" often found mounted on the "cavitation plate" ( actually anti-ventilation plate, but that is just my OCD ), just above the prop very likely will not be straight. It is adjusted to correct torque at speed. ie: if you are at cruise speed and "everything" is balanced you should need zero ( neutral ) steering input. If not that small skeg above the prop would be adjusted to correct to neutral steering input at cruise.
I hope I covered your question. If not, I hope you found it interesting...
