I knew this was discussed here before. Here you go Walter.
http://www.boatered.com/forum/topic.asp?TOPIC_ID=141920
These are the things I use. Cuts down on the damp rid, though next year I am buying the calcium chloride
http://www.ebay.com/itm/like/280851468985?lpid=82
Those look pretty cool. I just ordered a couple to try out.
How long before they change color in the cabin under the shrink wrap?
I use the calcium chloride when I have it around, but the tubs I get from Lowe's (Walmart sells them too), are not much more than what the calcium chloride costs.
I usually put two in the cabin, and one in the cockpit, and they last all winter.
Originally posted by mdoherty
Most dehumidifiers don't work below 45 to 50 degrees. The coils need to be above freezing and when the temps are below 40 there isn't enough temp drop to cause condensation.
Over the winter not too much, but like now and in spring, they would turn pink quick. I use both, damprid and these, so not sure if they would pull more water if working alone. They take 10 min in microwave on medium to turn blue again. The pink/blue is just litmus paper.
