Davits
What kind of dinghy?
Weavers are great for smaller dinghy's. I had them with their quick connect kit, which allowed you to remove the davits so they didn't get in the way of enjoyingthe platform.
ab 10ft rib 170lbs 70lb 9.9 yamaha
have only looked at hurley so far, I liked the rail mount system but not sure if it could handle the weight.
If you have an inboard Freedom Lift looks great. I have no personal experience with it, but I like the way it leaves the swim platform free. I'm waiting to hear back from the vendor, but does anyone out there have any opinions on this, and a rough idea of cost?
http://www.freedomlift.com/
Vic
Vic
I was quoted $18,500 plus install on a 42' Regal. Still trying to convince the Admiral it is worth it.
I have the Hurley davit on the swim platform and a lift w/winch for a cradle on the foredeck. I too have a 10' RIB, but with 4 stroke 8hp Yamaha.
Here's what I like about the hurley: It works as advertised, it's lightweight, easy to install and easy to stow.
Here's what I don't like; the price (way high for what you get), limited intstallation instructions for fine tuning the placement, with a RIB, YOU will work much more than advertised.
If you're plaform is more than 7" or 8" off the water, forget the Hurley for the RIB. If you're close to the water like me, You'll grow to really like how fast it is to launch and retrieve. We back into the slip so we store the dink on the foredeck at the marina. The first stop while we're out it comes off the foredeck and we use the hurley for the remainder of the trip because it's easier and faster.
One issue though; I have a short line to tie the davit back at about a 45 degree angle after launching. This is necessary to gain the mechanical advantage at retrieval. The davit hangs at 90 degrees to the swim platform after launch, so tying it back give me a ramp to pull up instead of pulling against a "wall". I cussed this thing for quite awhile until I figured that out. Now it's a piece of cake.
Thanks for the insight. Great info.
Only one short season on this boat but I believe the swim platform is probably about 7-8 inches out of the water when low on fuel. Anybody out there w/a 35 or 3760 w/ a better memory than me?
I have a hurley davit too. My swim platform is about 6" off the water. I find it real easy to launch and retrieve my dinghy without any mechanical help.
My total weight is less than yours though, probably about 150 lbs. I have a 9' RIB with a 4hp outboard.
That's plenty low enough for a Hurley.
Note: Our dinks are heavy for one person, especially in rough water (the Admiral is 98lbs soaking wet in sweats and a parka). I tie the bow line short (close to the boat) and do the pulling on the stern. That way I'm using the bow of the dink as a pivot point, leaving the stern to slide right into postion. Once it's retrieved, you can actually go inside the dink to add a strap or two. I'm paranoid, so I use four.
trust me, the first few times pulling on that RIB you'll be wondering what you wasted your money on. Once you find the sweet spot though, it's easy.
I have the Martek 250 system permanently mounted on our 36' Regal. Our swim platform is 14" off of the water. I will get some pictures and post them. We carry a 9' RIB Caribe with a 15 HP Merc with all of our gear inside (over 200 lbs). Plenty strong enough. The base of the uprights mount through the teak platform and I made supports to secure the high side of the upright to the top of the stern 36" off the platform. We have been in 6' seas with no problem. The ratio pulleys are a must. Wife and I pull it up and down easily and quickly.
You might want to look at Martek davits (google it). Their product line is similar to St Croix, but considerably less expensive.
Delaware Jim
