Deck Carpet for a wellcraft 3600 martinique
CAPTINMB
Hi all
Im looking for a company that has templets to make replacemet carptes for boats.. I might pick up this boat wellcraft 3600 in a few weeks and it dosent have carpet out on thr deck..
Any advice
Make your own templates using builder's paper. Lay down the paper and tape it together where necessary and trace around the perimeter using a sharpie marker, then cut out the templates. You can go to local carpet store and they will cut and bind the carpet. Then install the snaps.
Mike,
You can contact www.corinthianmarine.com directly by phone and they'll send you a template kit. It contains everything you need to do an accurate template along with easy instructions, etc.
I purchased a set of custom fit AquaMats from them, this past winter and couldn't be happier. We went with the cut and loop pile carpet.
hi mike my carpet was made by Taylor and they offer a replacement program where they send you material to make a template and then return it to them for a quote.
google Taylor Made
