I installed St Croix 400/401 davits on my 1995 model Carver 325. I tried a hundred different ways to get under the swim platform. For that reason I put off the job until last year.
The only option is to cut out circles for inspection plates, as that is the only way you'll ever get to the underside.
Also on my boat, the swim platform is balsa cored. I was surprised; I thought it would at least have been plywood. At any rate, you need to seal the balsa with epoxy and also you need some way to stiffen the underside. Fender washers won't do it. I used 4" aluminum channel.
I was able to get the aluminum channel fed to the inside of the swim platform from the cabinet in the aft cabin. Of course your boat will be different, but the idea is to find a path.
Here are some photos.
No two ways about it, you need to cut a couple of big ol' holes in the swim platform. I even checked with St. Croix as they show several Carver Aft Cabins with their mounts on their web page, and this is how they did those as well.
Next, I taped off the holes (or it will show as I am sloppy), and I used West Epoxy to soak the balsa coring really good.
Here is the aluminum channel I made. I started out with 3" channel shown here, as that is the only stuff the local supplier had, but the hole pattern was such that I had to cut into the sides. There are 4 channels, one for each side of each support.
Also you'll want to ground the channels to the boat's ground. You can see the green ground wire that I attached to the channels. St. Croix recommends this, and I have no idea why other than to drain any galvanic corrosion away to the zincs.
You can buy stainless steel channels from St. Croix, but for some reason they recommended using aluminum channels in their instructions. Never did figure that one out.
At any rate, you must use something like the channels to have sufficient holding power. Fender washers would probably simply pop through the balsa cored swim platform.
This ended up weakening the channels, as they bent under pressure of tightening the davit mounts down, so I later found some 4" channel on-line of all places (about $100 for 4 pieces), and believe-it-or-not, was able to replace them with the boat in the water.
I did this job last year before I launched the boat. The boat is 100 miles from my house, and I setup my mini-machine shop in the back of my pickup. I used a chop saw as I had to shorten the aluminum channels a bit to get them to fit.
Of course, this was all for naught, as I indicated I later replaced the 3" channels with 4" channels after the boat was in the slip.
Here is the shot you are probably most interested in, it shows the channels under the swim platform, mounted to the dinghy frame. You can already see where the aluminum channels bent. As I said, I replaced these with 4" channels that were wide enough that the mounting bolt pattern fit inside of the channel.
You will also want to use a liberal amount of 4200 sealant to seal everything when attaching to the swim platform.
Sorry for the poor lighting, but you can hopefully see the deck inspection plates installed in the holes that I cut.
I kept the hole cutouts as one day, I might teak the deck, and if I do, I'll permanently attach the 4" channels to the underside with captive nuts, then put the inserts back in, under the teak decking... or at least that is what the admiral has on my list.
One issue I do remember is that it was a bit difficult to determine where to place the support cages. There are a few obstructions in the way in the swim platform (the recess for the boarding ladder for one), and the placement was a bit limited.
However, I was able to place the support cages so that I still have use of the swim ladder, and in fact, they become an asset as there is now a hand hold to help board via the ladder.
As it turned out, the spacing is just a bit wide for my dinghy. But the cantilever action of the mounts work perfectly and self-adjust to the dinghy.
However, my dinghy is only 9ft and something inches; which means.... maybe a larger dinghy is in my future.
The other thing I discovered, is that you have to get the dinghy right up as high on the davits as you can during boat operation, as the boat squats quite a bit underway, and the dinghy can actually hit the water as you go onto plane otherwise.
When the boat sits in the slip, we usually leave the stern end of the dinghy quite a bit lower than the bow, so that any rain water that collects will easily drain out.
And for some reason, the davits tend to become a Jungle-Gym of sorts for spiders. They seem to love it.
Hope this helps. I'll try to find a better photo of the deck plates.
