Double checking, block drains on 454 Crusaders
Mike Dzurko
1991 Crusaders 454 raw water cooled. Found and drained the blocks on the port sides of the engines. Could not find drains on the strbd sides? Did find a sensor in the area on one engine, can't get to that side on the other engine. I've read here that you just need to drain one side . . . will be filling with antifreeze from the thermostat . . so I'm just checking so I can sleep well this winter :) Thanks!
