Drive oil was drained for inspection because I found some metal shavings when I had the drive off to replace the gimbal bearing. My question is in regards to refilling the drive unit with oil.
Do I just add oil to the resevoir?
Is there a bleeding procedure?
I ask this question because I found a vent screw, I thought maybe this would facilitate filling the drive correctly.
I have a 1994 5.0L merc, alpha1
Thanks for any input.
