Originally posted by Michael Clemensen
Judgement call, why are you pulling the engine, fit, repower, etc. I'd look at the coupler splines and see if they are worn, sharp. This occurs if the stern drive shaft isn't greased frequently, the tilt and trim will cause wear on the spline which are sometimes aluminum. If your going to increase the H.P. of the engine is another reason to start out with a NEW coupler,
