engine half power
BRSahoy
I have a 2006 I/O boat with a 5.0 volvo penta. Recently the engine was completely submerged in saltwater (for about a twelve hour period). The marina immediately pickled the engine after it was salvaged and it ran smoothly. I let the boat dry out for several days and then cleaned/oiled all the electrical connections, starter, alternator, etc.. Most of the electrical connections seemed to be unaffected, as they were all gasket sealed. After this I started and ran the boat in the driveway for about two hours. The engine ran smooth and sounded good to an inexperienced ear like mine. When I put the boat in the water and ran it I soon found out that the boat was not operating how it should. When I would engage the throttle all the way it seemed as if the engine was only at half power. The boat would only get up to 20 MPH, whereas it normally runs 45 MPH. Is this an engine problem, elBrad ectrical? New ignition wires, spark plugs? Any advise would be appreciated! Thanks.
If the boat sank (kind of what it sounds like) the electrical gremlins will start to show up later as the wires and connections start to corrode. For now, probably water in the fuel system.
I'm not discounting any issue with the powerpackage, but are you sure you got all the water out of the boat as well? Water is heavy and you could be trying to haul a lot of extra weight around.
JP
All the water is out. Water in fuel sounds like a possibility. Is there any kind of additive that could help with this? Also, what is the best way to test the ignition wires? Thanks for the help. Brad.
I'd be getting my insurance company involved now if you haven't already. You're likely to have some major issues after 12 hrs in salt water. I'd be suspect of every bit of wiring in the boat.
When the boat was submerged, water probably made it's way into the tank. The remedy is to siphon out all of the gas and change the filters. If you have a water seperator filter make sure you do that as well. When you refill the tank add some dry gas.
Relatively easy fix if that is your problem. It may not be the only problem but should be done anyway.
sounds like a wet distributer moisture rises up to the contacts on the cap pretty common around here it can be hard to get the water out from under the dist weights as it often won't go thru the vent screen in the base
If it were my boat, I would have every single bit of electrical equipment and wiring completely replaced. That would included everything on the engine. And I'd replace all the fuel, etc.
I hope you have good insurance!
Lots of later generation Volvo Penta marine packages have electronic protection which limits engine RPMs if there is a "sensed" problem. On my boat it is 2000 RPM. Could this be a player?
Water started the problem,and that is where you should start looking first. Check first in your fuel tank then move up the line to filters and the fuel delivery system you have. If these show no evidence of water fouling add a can of waterzorb(available at Boatfix) just to be safe. I have used this product with very good results. If this does not help then the next step may be sensors or other electrical problems.Remove all water and moisture first Because! that is what changed. Hope it helps.
