I have a crack in my deck and I was looking for advice on what may be the best product to try to fill the crack. The crack is more than a simple hairline and would be great if it could take some flexing.I have tried life caulk but it fails.
Deck should not flex... impossible to tell without more info incl boat type, crack location and deck construction. If it s more than a hairline gelcoat crack, it s likely structural. Does it go thru ? Is the deck cored? If balsa core you need to solve this asap. You may get away with grinding it open and just filling it with thicken epoxy, if more serious you will need to reinforce with glass
