I have a 2003 Chaparral 320 and the facet in the aft cabin has gone bad, I can not shut it off. Does anyone know where I can get replacement parts,I need new stems
Also look at plumbing fixtures here on BoatFix as well as other on line marine/RV suppliers. I have found RV dealerships also have them if you are in a hurry.
I believe 4" center is plumbing standard. If you deem the faucet too expensive to fix because it's a "boat" faucet, a local hardware supply store may have generic replacements or you could get another faucet entirely. Faucet connection adapters should be on the current faucet. Sharkbite fittings make the job a snap if any cutting is required.
[EDIT ADD]
Check your RV places as well. I believe Fontantas come in some RV's.
I was on my way to a RV Dealer and stoped in the local Lowes and bought a Pfister Classic Model F-WL2-20NC faucet. The couplings matched exactly; put it in in about 15 minutes and it works great. Matches what is the head sink and the aft bedroon sink. It cost $19.00
