FW system leak help
Quint
91 Carver 260 command bridge. I have a water leak somewhere in my FW system and I can't get to where I believe it is. I believe it's the galley sink side below the cabinets and fride in the bilge area. I see no access panel anywhere for there. My head sink has good pressure but the kitchen sink is very weak and I can see water flowing straight down the bilge in the engine room. Any suggestions? I'll try to post pic of my cabin layout.
How do u post a pic I have the pic in my pics on my computer?
use photobucket.com to host the pic.
The cut and past the IMG path from the pic in photobucket into your reply. Pic should show up.
As for your water leak, hard to help there. Is it a cracked hose or a fitting?
Dave,
This may sound too easy but can you just pull or push a new piece.
Billy K.
Is your fridge mounted below the sink? If so...just unscrew it and pull that out to gain access to the plumbing. (sink drains etc.)
