I have a 480DB searay, and would like to get better water pressure at my showers. The original configuration is two 3.3GPM at 45PSI Shurflo pumps in parallel. I do not think there is an accumulator tank.
I am thinking about putting in the newer variable speed pumps that put out 4.5GPM at 50PSI and restrict them down to 45PSI.
Will this solution be adequite and not require an accumulation tank? Will these newer variable speed pumps work well in parallel?
Thanks for any help with this. And then I will need to get quotes for the parts.
