Hi all.
Looking to get my boat in the water this spring for the first time in 3 years (motor mount stringers were replaced)
Looking to install an older Onan MAJB 3 KW over the winter. I had installed a 4KW Westerbeke years ago but yanked it because it caused the boat to list to port considerably being that it weighed 300+lbs and it was off the centerline to the left of the port engine.
So now that I have a 170lb Onan, do I install it in the same place as the Westerbeke and hope the 130+lb difference is substantially noticeable with regards to the list?...or do I install it centerline on a wood step in front of the engines?
The potential issue with centerline in front of the engines is the wood step would be about 8" above the very back of the fuel tank...where the lines come out of. Assuming the genny is grounded and installed correctly, is that still a fire hazard? Is it coast guard compliant?
Thanks for the info as always.
--Rick
--Rick
