What is noisy? The engine or the water splashing out of the exhaust?
If the engine is noisy, the only solution is a sound shield which is costly and cumbersome. Unfortunately many if not most small Kohlers are 3600 rpm units and a lot noiser than 1800 Westerbekes or northern lights
For the water noise, it s normally not too loud but you can install a water separator which will help.
One lag thing, make sure the higher exhaust noise isn't caused by low water flow. I ve seen this a few times, there can be enough water to keep it running but not enough to fully muffle the noise
