GPS installation
ALKA2710
Anyone recommend someone who can install a GPS with a thru hull transducer in the Nassau County area.
Al
Al,
First Id like to thank you for posting. We at LICC welcome u with open arms . ( some more then others ) As ofr ur post u can try CMI Electronics at 1-631-225-3672, Great guys .
Also please check the LICC folder for more info regarding Other vendors.
Again thank you for visiting LICC....
I second CMI.
Also there is Sea-Curity in Lindenhurst 631-226-1616
Originally posted by Robski97
Al,
Looks like Rob is our new ....P R guy !
unless i'm mistaken (which happens more frequently the older i get), a transducer (either in hull, thru hull, or transom mounted) is for a depth gauage, while an antenna (either internal to the gps or externally mounted) is for a gps.
Bruce,
Many of the new GPS units are combo displays for both GPS and Depth finder capabilities, as such you would have both a transducer and an antenna
thanks. i didn't realize that. too bad someone can't come with a transtenna or an anducer. would simplify things a bit. ;-)
