How to seal engine cover
JMP
The engine cover (stern drive) is hinged to the deck at the bottom front and is leaking water mostly along the top of the cover. There is a small piece of aluminum channel under there but not doing a good job. Deperate to stop engine corrosion problem from this. Would consider to seal all around if possible.
JMP
