Originally posted by dlong90210
Just wondering if anyone knows when the Ice will be out either on the Mississippi and the St Croix River here in MN?
Historically, depending on snow melt, rains, temp, ice out on both rivers comes about late March, to mid April.
Boating the rivers after ice out is another matter. If there's a lot of runoff which causes elevated water levels, there will be a ton of garbage in the water. Dead-heads...the ones you can't see which are just a few inches under the surface will take a drive out quickly...or the bottom of the hull. If we actually get flooding, you can forget the rivers til about late May.
The St Croix up your way is largely a no-wake zone down to Stillwater. From Stillwater to Prescott, WI, it's a friggin zoo. Very congested boating river, so I avoid it at all costs...you can walk across the the St Croix just by jumping from boat-to-boat.
I don't boat the Mississippi up your way, so no help there.
If you trailer your boat...drag it down to at least below LD #2 (St Paul) and run the descending bank towards Red Wing. The traffic thins out by the time you get to LD #3. From Red Wing all the way to LaCrosse, WI, there are five LD's and makes for a nice, long cruise with minimal traffic. Finding gas is no problem. Most gas docks are open by late April.
The best boating is the 22 mile long Lake Pepin. Gets a little choppy in spring with a prevailing westerly wind and a long fetch...four footers are typical in the middle-upper end of the lake.
Just set a fast idle, brings copious amounts of liquor and enjoy the scenery.
