I have an ICOM M402 with a problem when transmitting. Seems when I try to transmit the unit will beep and display all characters on the display and stop transmitting. Wondering if anyone else had the same problem?
More information, I checked the SWR and it is OK so antenna seems to be OK. Receive is OK, as is low power setting which by the meter is about a 1 watt. Seems to be a high power transmit problem and once in awhile it will work for a few seconds. Could be a heat related problem. I called ICOM and for $50 they will give me an estimate to fix with a hourly rate of $90. So their recommendation is to “buy new" and forget trying to get it fixed. Sound familiar? This unit is also one with the remote microphone capability which I installed so I can use on fly bridge or cabin. I found out you can't use the mic or cables from the M402 for any of the new radios so would need to rewire everything. This unit is DSC capable, which leads to another issue. How do you un-program MMSI code in the unit?
Has there been reports of emergency call from a radio with the wrong MMSI numbers? Are you libel for not removing the code? So what do you do with a mostly receive only radio (low power only)? Car, home, junk pile, sell it or just trash it?
