- Jul 27, 2001
- 5508
- 1,236
Some may remember the motor in my bowrider, it’s a 1999 454 bravo, used to be mpi, but a couple years back the rusty mpi was acting up and after two shops couldn’t straighten it out, I retrofitted a carb and DUI ignition. I probably should have just repowered at the time - but the compression was perfect, oil pressure right at spec, and I did get a couple good seasons. However, it’s still a 26 year old raw water motor, used in saltwater its entire life.
Which brings me to this year. Boat ran fine first few days this season, but yesterday bilge pump came on ten minutes from the ramp. Water was pouring out side of motor, right above the starter, and deep enough that it was getting thrown all over the motor and accessories. Turns out the freeze plug was no longer in the block. Found the brass ( bronze?) plug in the bilge. It looked fine, but had some ‘motor’ stuck to it. I was able to reinstall it ( way too easily I suspect) with some permatex to hopefully hold it in ( jb weld might have been better). Boat started right up, and ran it about three hours, not a drop leaked out. But it wasn’t running great; at cruising speed and above ran 100%, but at idle and no wake speed it was running rough. Shut it off to dry some things out, then it wouldn’t crank. looks like I killed the starter with salt water, because battery was close to 13 volts.
I know this motor is about done, when the freeze plug was out I was reaching inside and pulling out scoops of rusted metal. But this is not the ideal time of year for a repower. Thinking about throwing a new starter in this evening, re-testing the compression, confirming the oil still looks good, and trying to make it another two months.
Anything else I can check, before or after starter replacement, to better predict the hours left on this old block? Has anyone ever brought back a dead starter / solenoid after a salt water soaking?
Still wondering why the plug came out in the first place. There is no pressure on the raw mater cooling. I really don’t think I botched the winterization. Mainly because I had run the boat 10+ hours this year before it gave way. There have been some years where I’ve been in a rush, and didn’t pull the thermostat when winterizing; but this wasn’t one of those years. Only thing I am wondering is if all of the rust I scooped out was clogging up the motor and not letting antifreeze to that section. But since it wasn’t out right away, still thinking that is unlikely.
