Installing Snaps
WALSHIE
Well-known member
Hi, I received a replacement top from Gioa Sails. I borrowed a snap tool and am ready to install the snaps.
Any words of wisdom? Start from the center, etc?
Any advice would be appreciated!
Get a helper And install all the windows and curtians before you start snapping.
Start in the center and mAke sure your corners all line up right with no wrinkles
Pull tight,real tight before you cut the snap in. This is a two person job IMHO.
Well, I installed the bimini top and all of the old cutains, they all lined up. Only the front panels are bad enough that I have to use new. I could have saved money replacing the top and the fronts but I'm glad I ordered everything.
With the top on, old sides and rears installed AND SNAPPED, I will start at the front center using the old as a guide while stretching the new. Once done, I will have a complete top and from there, I can do one panel at a time.
I'm shocked at how well the new lines up with the old! It makes this install just about "stupid proof"
