First, thanks to all who post here. I am a 2nd year boater with a 12 year old boat (Larson 28' cruiser), and I have learned a lot here. My issue:
I have a Jabsco 37010 electric head. It worked fine for a while, then a guest put some Kleenex down there, and it clogged up (my bad- guest education has since been beefed up considerably!). After I got the bad stuff out, the motor would still seize up- I would press the button, the overhead light would dim, but nothing happens. So it took the whole thing apart, cleaned it out, and got it back together. It worked fine a for a day, and now the same thing, no flush. I think the electric motor is OK- it runs nice and fast when I have it apart. I suspect one of the washers or seals is bad, but I cannot guess which one.
Also, there is a slow leak that seems to come out of the motor when it is 'trying' to flush.
Question- would installing the $60 kit of replacement parts likely fix this? Or should I start over?
