Originally posted by November Charlie
Start at your battery and get eyes on everything electrical all the way to your console components. You COULD isolate the fault simply by resistance, but 1988? 30 year old electrical system in a marine environment - get eyes on every bit of it. Keep in mind current ABYC color codes are slightly different - nowadays negative should be yellow, not black, for example. Bonding should be green or unshielded. If multiple components are flaky, you’re looking at a main or common ground (more likely) corroded away. So, not to Barney it, but you need to focus your search on where bigger wires go into somewhere or something that more smaller wires come out of. That is where your most symptomatic fault will be, but NOT your only one. Proper marine grade wire is tinned copper - copper gets wrecked in short order with intermittent salt and oxygen exposure. Slightest crack in the insulation from an unprotected bulkhead penetration, sharp bend, or UV exposure, or just plain age, and even high end wiring is turning to green dust. And green dust is not nearly as conductive as tinned copper.
