Lectra/San MC
Vic, I have access to LectraSan unit while dry docked.
By electronic control unit; are you referring to entire part that is covered by blue plastic control cover? If so, that would require removal of wires from fuse block to Mixer Motor, Electrode Pack & Macerator Motor; correct ?
As much trouble as it is; I’m toying with the idea of removing entire unit & dropping off for a complete check up in case trouble is in other area outside of control module. Sending a PM to you re a more personal matter.
Bob, yes that would necessitate removing several of the wires. Bringing the whole thing in to us might be the way to go.
