I just got this from a friend. I didn't know why Maptech wouldn't send me any maps...
Maptech has been sold and the "free boat chart" link has ended; however, all is not over! The charts are still available FREE from NOAA.
All of the charts that Maptech distributes via the free boating chart download site are created and maintained by NOAA. They own the actual chart files, so they aren't going away. All of these charts are available directly from NOAA at:
http://nauticalcharts.noaa.gov/mcd/Raster/download.htm
It is different from the Maptech site, but it's not hard to download specific charts. The only trick is that you need to know what to do with the files when you download them. Maptech provided a file that automatically installed the new charts into Maptech. When you get them directly from NOAA, they come to you in a compressed ZIP format. You have to open the file and copy them to your Maptech directory.
To load these files into Maptech, do the following:
Start Maptech
From the Charts menu select "Chart List".
From the Chart List menu click on the "Advance Chart Management" tab.
This tab will show you the list of active directories that contain chart files. Make a note of the first directory on the list.
Close Maptech.
Open the download from Maptech. Copy the individual files to the Maptech directory identified above. If you download multiple charts, they may be in separate directories. You will need to open each directory and copy all the files from each directory into the Maptech directory.
This process is a little more complex, but shouldn't affect our ability to use these charts. They will continue to work with the Maptech software we already have, so there should be absolutely no change in our present capability.
Start Maptech
Close Maptech.
