Anyone has recent knowledge or info on the Mercruiser Diesel D-Tronic 4.2L 250 HP? Every time I search for information on these engines on the Internet I get messages, forums, etc from 2007, 2008, etc.
Both my engines are having exactly the same problem, when you start them they accelerate by themselves all the way to WOT and then they stop. After this, they do not start for a couple of days and all of a sudden they start again and the same thing happens. We hooked the engines to a computer and the error message is that ALL sensors are "out of range". We have tested every electrical part of the engine with new parts (Computer, Electrical harness, sensors, instrumented injector, serviced injectors, serviced fuel pump, timing, etc.) and nothing works. Any idea what could be happening?
THE SAD STORY:
My boat is a 1998 Searay Sundancer 330 with 130 total hours on it!! when I bought it it had 104 hours. The boat really looks and worked like new when I got it, but the fantasy died when the engines started failing!!
The first engine died after using the boat 4 times and 17 hours!!! One cylinder head cracked and the piston connecting rod bent, so I performed a complete overhaul on the engine which took me 7 months to find the parts and $ 12,000.00 to complete.
Once the first engine was fixed, we took the boat out and used it 3 times and 9 hours and then the other engine died. But this time the mechanic said the problem was not that bad, it was just a cylinder head gasket and a defective injector. It took me 2 months to get the parts and I sent the other 5 injectors to get serviced. After spending another $ 6,500.00 to get this engine working, it never really did. So the mechanic started testing parts from the working engine on this one to see what was wrong and never found out what. After reassembling te first engine back with its original parts, NONE of them worked!!!
We found another boat with the same engines both in working order so we tested all parts of these engines in my engines and they did not work. It has been one year since the second engine died on me and I have no hope whatsoever to get my engines running again.
So, if help on how to fix the engines can not be obtained, I'm considering the option of installing new engines, but I really do not want to spend $ 45,000.00 + labor on two new diesels, so my question is, can I install 2 new gas engines instead? What size should they be? (5.7 L, 7.4L) Will my Bravo III X Diesel outdrives with 1.81 Ratio work with gas engines?
Thank you very much for any advice.
THE SAD STORY:
